driveline slack? newbie
Old Sep 4, 2008 | 11:06 PM
ridered4life's Avatar
Unhappy driveline slack? newbie
ok so basically here it is. Im sitting at a stop light, the light turns green, and when i push on the gas pedal, there is slack in the drive line that slaps to attention as i go. this only happen when i semi jump on it off the line. if i slowly ease into it, then the jolt doesnt occur. i know nothing about transmissions and select things about drivelines. my knowledge is all in suspension. also, when the truck is in park, i can rotate the drive shaft back and forth a bit. do you guys have any ideas as to what it is? the truck has 100,000 miles on it and the person who owned it before me towed a trailer with it. do you think its the u-joints, gears, transmission?
Old Sep 4, 2008 | 11:28 PM
SpoolinChevy's Avatar
Mine has a little bit of play also. I was worried about it until i tried my dads Cummins and his was a little worse then mine. I'm not sure if it's a bad thing or not?
Old Sep 4, 2008 | 11:38 PM
95 bright teal's Avatar
I would check your tranny mount, my camaro would tear the stock ones in half and back the screw off the performance ones.
there is a bolt going through the mount, make sure its tight, and the mount looks good(no tears)
Old Sep 6, 2008 | 01:00 PM
j225's Avatar
check the driveshaft slip yoke.I think thats what its called.Had mine greased and it stopped for a few months but is now back.I believe i heard something about a nickel plated yoke that fixes the problem
Old Sep 6, 2008 | 02:19 PM
ZZebes's Avatar
Nickle Plated Slip Yoke FTMFW
Old Sep 6, 2008 | 02:24 PM
so with the slip yoke is it just spinning freely or moving back and forth? i dont get it
Old Oct 13, 2008 | 02:36 PM
me either. i was thinking it might be the gears in the rear end because they have 130,000 miles on them.
SloSVO
Nov 22, 2020 07:34 PM
nickpc82
Nov 2, 2015 02:49 PM
iregret
Sep 7, 2015 01:20 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
supersportsteve
Jul 4, 2015 12:02 PM
