driveline slack? newbie
ok so basically here it is. Im sitting at a stop light, the light turns green, and when i push on the gas pedal, there is slack in the drive line that slaps to attention as i go. this only happen when i semi jump on it off the line. if i slowly ease into it, then the jolt doesnt occur. i know nothing about transmissions and select things about drivelines. my knowledge is all in suspension. also, when the truck is in park, i can rotate the drive shaft back and forth a bit. do you guys have any ideas as to what it is? the truck has 100,000 miles on it and the person who owned it before me towed a trailer with it. do you think its the u-joints, gears, transmission?
I would check your tranny mount, my camaro would tear the stock ones in half and back the screw off the performance ones.
there is a bolt going through the mount, make sure its tight, and the mount looks good(no tears)
check the driveshaft slip yoke.I think thats what its called.Had mine greased and it stopped for a few months but is now back.I believe i heard something about a nickel plated yoke that fixes the problem
iregret
Sep 7, 2015 01:20 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
