Driveline angles and launch shudder.
Old May 28, 2011 | 07:11 PM
scooter k's Avatar
Default Driveline angles and launch shudder.
I have a slight launch shudder on acceleration. I have lower it 3/5 with a rear McGaughy's flip kit. I measured the angles today. My front angle is 6 degrees, driveshaft 0 degrees, and rear pinion 6 degrees. My working angles would be 6 and 6. I believe that is too much. I think I need to shim the transmission mount to decrease front angle which should raise the driveshaft angle. I also need to change the rear pinion angle by tipping pinion nose down to decrease angle. Does it sound like I doing this right? Which shim do I need for the front and rear?
Old May 28, 2011 | 08:30 PM
SincalT/A's Avatar
You should probably explain where exactly your measurements came from.When you say 6 degrees is that positive negative also what are you 6 degrees out from could be the ground,chassis,crankshaft?
Old May 28, 2011 | 08:36 PM
scooter k's Avatar
I'm thinking now that I probably just need to move the pinion nose down.
Old May 28, 2011 | 08:46 PM
SincalT/A's Avatar
Pinion angles within 1-4 degrees negative from the driveline.Is where most leaf spring setups should run.In other words yeah your pinion needs to be down a lil.
Old May 28, 2011 | 08:54 PM
scooter k's Avatar
I measured it with an angle finder. Front is 6 degrees down and rear is 6 degrees up. That make any sense?
Old May 28, 2011 | 09:48 PM
SincalT/A's Avatar
Is the trucks suspension leveled and loaded.Meaning when your taken measurements its not jacked up by the chassis.
Old May 28, 2011 | 10:02 PM
scooter k's Avatar
On a drive on hoist, weight on suspension, and level.
Old May 28, 2011 | 10:50 PM
SincalT/A's Avatar
OK so a real quick step by is to:
-Get the driveshaft parallel to the crankshaft or close as possible.
-Now measure the difference if there is any of the pinion to the driveshaft in relation to the ground.If I understand correctly you have a pinion that is pointed 6 degrees towards the ground with parallel being the start 0 degrees.
-Now your driveshaft is 6 degrees up from parallel to the ground correct?
Old May 29, 2011 | 08:37 AM
scooter k's Avatar
Yes mine is 6 degrees up from parallel to the ground.
Old May 29, 2011 | 04:51 PM
BadAssChevy327's Avatar
mine measured 5 degrees up after shackle and hanger, i did a 15 dollar procomp 6 degree shim. now im sitting at 0. i wish i went with a 8 or 9 degree but that would a giant *** shim lol.
