Dragging caliper?
Old Jan 18, 2011 | 12:18 PM
BLUES MAN's Avatar
The House is Rockin'
Default Dragging caliper?
wheel for the last couple days i have noticed that my rear passenger wheel and rotor is getting hot as a SOB so im guessing its either the caliper sticking, pins need to be greased, or the rubber brake line. its only happening on that side, and i just turned the rotors, and put new pads about 2,000 miles ago. anyways is there anything else that could be the culprit
Old Jan 18, 2011 | 12:58 PM
iamkeniff's Avatar
normally its a lazy caliper so just change both sides to be on the safe side.
Old Jan 19, 2011 | 09:11 AM
BLUES MAN's Avatar
well this morning i took the caliper off, and the rubber around the piston was starting to come off. i cleaned it up real good and put it back on, took it around the block and it wasnt getting hot. but this weekend i probably will just just change it out.
also does the whole system have to be bleed or just that side?
Old Jan 19, 2011 | 09:55 AM
aeorozco's Avatar
You should still bleed the entire system -Doesnt take long, its a pain to get down and do it but its better to spend and extra 5 minutes doing it and making sure that there is no air in the lines at all and can eliminate that off your list and try to narrow the search for the sticky caliper.
Can I ask if these new pads are ceramic? I remember when I put ceramic on my truck for the 1st time my rears would get hot and smell alot, I did have a bad caliper that was sticking but its since been fixed. I am wondering if maybe you are smelling the ceramic off the pads??
Old Jan 19, 2011 | 12:54 PM
ZR1 DREAMING's Avatar
I just put new calipers on the rear of the SS, it had sat for a while and once I finally drove it the rear calipers were hanging. I say 2 new calipers, rear pads, and bleed it out the system and you won't have any further issues. No leaks on your lines right?
Old Jan 19, 2011 | 04:31 PM
BLUES MAN's Avatar
negative on ceramic pads...
no i def do not have any leaks in the lines, i guess i'll change them both out. but actually after i cleaned the caliper off real good, it doesnt seem to be sticking now! maybe it will buy me another month
Old Jun 4, 2011 | 09:53 AM
flippindabird's Avatar
sorry to bump an old thread, but i have been having this same problem for some time, and ive been getting new pads like every6 months, this time ive had to replace the rotor... if i am going to replace the caliper and bleed the system i feel like i should be upgrading the caliper, its not like this thing stops on a dime and any extra braking force will help, so what are my options as an upgrade?? i will do a search but if someone could point me in the right direction id be extremely grateful... thanks for any help
Old Jun 4, 2011 | 06:17 PM
Beatdown Z's Avatar
Laid Back
Install SUV dual piston calipers, pads, and rotors. https://www.performancetrucks.net/fo...+brake+upgrade
It's the best thing I've done to my brakes so far. Next is hydroboost.
Old Jun 6, 2011 | 09:20 AM
BLUES MAN's Avatar
yeah i have had my problem fixed for awhile now, anyways it was a bad caliper, replaced both sides, fixed!!!
Old Jun 9, 2011 | 05:54 PM
lol beatdown your like PT.N superman! thanks again man i just found that thread too... so it is my caliper! wish i would have known that a couple weeks ago i paid half the price for my stock replacement junk, def doing it when they start acting up again... should i just replace the lines too??
