Drag tires??????
Old Feb 17, 2008 | 09:33 AM
Red04Silverado's Avatar
Default Drag tires??????
Hey I have a 04 Silverado with a 4/6 drop. I would like to get some drag tires for my factroy 16 inch rims or I do have a set of 18in (5.0 backspace) centerlines I dont use anymore. Does anyone know what size would fit my drop for any of the two wheels? Also what brand would you recommend? Thanks
Old Feb 17, 2008 | 11:23 AM
chris04's Avatar
they make et streets and drag tires for 16 inch rims it depends on what size you want and can fit, you can get a 26, 27, or 28 inch tire for height and it also depends on your mods, i have to have a 28 inch because of 4.10s and stall to hook up,both hoosier and mickey thompsons are good slicks imo
Old Feb 17, 2008 | 11:29 AM
chris04's Avatar
and by the way if you want to know where to get them i just looked at them on jegs.com so you can find them there man
Old Feb 18, 2008 | 08:09 AM
terravast4's Avatar
If you use a et street on a stock 16" metal rim will it fit say a 28x11.5?
Old Mar 4, 2008 | 10:28 PM
chris04's Avatar
yea they should work fine, there is a member on here i saw the other night thats running a 27" with 11.5 on stockers.
Old Mar 4, 2008 | 10:39 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Does anyone know with 26 inch tire for height What gears should I run? Thanks
Old Mar 5, 2008 | 12:27 AM
Turbo-T's Avatar
410 gear because like me the 16" is the only rim u can put on your truck I have a 16" mt et and they are ok at times but I think I would be better to go with a 18" because more and more slicks are being made in that size.
Old Mar 5, 2008 | 12:47 AM
SpoolinChevy's Avatar
i have 3.73's and im running the 27" Et street on the stockers. I got mine and tubes off of jegs also.
Old Mar 5, 2008 | 11:35 AM
brodystruck's Avatar
Yes, but you'll have less sidewall flex, which is a contributor to traction. And you can run a 15" rim on your truck; just takes a little bit of grinding. I run 28x10.50x15 MT slicks at the track...
Old Mar 5, 2008 | 01:00 PM
255/50R16 be good with 3.73 gear???
