Does a Gear Change Affect the Shift Points on an Auto?
Like said, the speedo will definitely be off due to gear swap, and you'll also probably have TCC (torque converter clutch) issues with the lock/unlock acting weird.
On my 02 Silverado, I had shift points and RPM points dialed in very nicely, then scored a set of slightly shorter tires and for the two days or so before I reflashed the pcm with the correct tire height, it shifted fine, but acted a little funky on the highway and at higher cruise speeds...I'm going to say due to the different than tuned for RPM's/MPH's with the shorter tires.
Re'flashed with correct tire heights, it's back to shifting and locking normally.
LCHEE
Oct 24, 2020 04:10 PM
ferrellrooster
Jul 17, 2015 07:07 AM
