Does a Gear Change Affect the Shift Points on an Auto?
Old Aug 20, 2008 | 08:13 PM
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by dug
thats weird. If the shift points are based off of speed, you would think since the speedometer changed with the gear it wouldnt matter.
its a bit of both actually
Old Sep 17, 2008 | 06:34 PM
norris_83's Avatar
Like Scott says, the pcm is told to change at lets say 5800rpm, the 35mph stored is the max speed the gear can go before changing.
Old Sep 19, 2008 | 01:45 PM
zo6freak's Avatar
See i thought that if you changed gears, the tune shifts at whatever RPM you have it set at. When you drive a manual you dont watch your speed and then shift...
Old Sep 19, 2008 | 05:55 PM
rel3rd's Avatar
11 Second Club
It still will, but there is actually TWO things that need to happen for WOT upshifts...one, it needs to meet or exceed the MPH that is set in the WOT upshift parameter, and two, it must also meet or exceed the set RPM. If BOTH things do not happen, then it will not shift at WOT.
Like said, the speedo will definitely be off due to gear swap, and you'll also probably have TCC (torque converter clutch) issues with the lock/unlock acting weird.
On my 02 Silverado, I had shift points and RPM points dialed in very nicely, then scored a set of slightly shorter tires and for the two days or so before I reflashed the pcm with the correct tire height, it shifted fine, but acted a little funky on the highway and at higher cruise speeds...I'm going to say due to the different than tuned for RPM's/MPH's with the shorter tires.
Re'flashed with correct tire heights, it's back to shifting and locking normally.
LCHEE
Oct 24, 2020 04:10 PM
1979rs/z28
Sep 23, 2015 08:39 AM
meadows
13
Aug 25, 2015 08:29 PM
ferrellrooster
Jul 17, 2015 07:07 AM
