Does anyone know how many splines are on...
Old Oct 12, 2006 | 09:48 PM
Stampede4ever's Avatar
Default Does anyone know how many splines are on...
the tail/main shaft of an automatic trans for a 4x4, 1/2 ton, that fits in the transfer case?
Thanks.
Old Oct 13, 2006 | 01:58 PM
12secSS's Avatar
What trans is it? The tailshaft has the same spline as a TH350/TH400 if it is a 4L60E.
Old Oct 13, 2006 | 02:32 PM
Looking the all of the auto trans, that are available for 98 and up?
Thanks.
Old Oct 13, 2006 | 03:19 PM
12secSS's Avatar
Yes, it is the same as the 98 up models.
Old Oct 13, 2006 | 07:07 PM
How many would that be?
Thanks.
Old Oct 13, 2006 | 10:26 PM
DrX's Avatar
DrX
Tried to find an end-on shot but couldn't. Could only guestimate from these pics. This is FLT's 4X4 Billet Output Shaft.
Old Oct 15, 2006 | 10:12 PM
Need to know both of them.
Thanks.
Old Oct 16, 2006 | 12:07 AM
DrX's Avatar
DrX
Looks like 27 spline on a 4l60e. 32 spline on a 4l80e.
Here's an excerpt from the t-case section of the service manual:
There are two versions of the NVG 246 EAU, which depend on the transmission applications and vehicle applications. If the vehicle is equipped with a transmission RPO M30, the transmission splines in the input gear will have 27 teeth. With this application the planetary carrier assembly will have 3 pinion gears. If the vehicle is equipped with transmission RPO MT1 or MN8, the transmission splines in the input gear will have 32 teeth. The planetary carrier assembly on this application will have 6 pinion gears.
SloSVO
Nov 22, 2020 07:34 PM
97_ek
Sep 23, 2015 09:16 PM
MikeD.
Sep 17, 2015 09:39 PM
iregret
Sep 7, 2015 01:20 PM
