Does an aftermarket TC put more stress than a stock TC on the tranny?
Old Sep 25, 2006 | 06:48 PM
YenkoST's Avatar
Default Does an aftermarket TC put more stress than a stock TC on the tranny?
Well....just like the title says....I have research but really couldn't get a true answer. I have a stock 700R4 with corvette servo, B&M shift kit, and .500 boost valves. Just wondering if this will hurt the durability of the tranny, help, or stay the same? Thanks!
Old Sep 25, 2006 | 06:58 PM
i dont know about stress but i know that it has more friction and more heat so you'd need an aftermarket cooler
Old Sep 25, 2006 | 07:29 PM
TouchOfEvil04's Avatar
The stuff you have done to tre tranny will help your life. Adding a aftermarket TC will cause your temps to rise which willl cause wear faster.
This is where a aftermarket cooler comes into play to even that out.Cheap insurance usually around 60ish bucks.
The TC will cause a little more wear on launches as you will be leaving the line with more hp goin through the tranny and rest of drivetrain instantly.
Unless your making alot of power though it's not a problem.
More of a problem on the rearend than the tranny really.
Old Sep 25, 2006 | 07:43 PM
Coban's Avatar
I thought i had heard of guys breaking input or output (can't remember which) shafts with just a stall and little else. It will put more stress on the parts. Think about 250 horses hitting suddenly vs building up to it.
Old Sep 25, 2006 | 07:51 PM
Mangled03gmc's Avatar
Baltimore Whore
Yes indeed there is more stress put on the trans when you run a bigger stall. It is letting the motor get into it's powerband more before it locks up, inturn puts more strain on everything. Like said above all the goodies you add to the trans will help.
Old Sep 25, 2006 | 07:53 PM
KySilverado's Avatar
If the STR (Stall Torque Ratio) of the converter is higher than the stock converter and good aftermarket converters usually are. You will put more torque into the tranny than with the stock converter.
Old Sep 25, 2006 | 08:59 PM
YenkoST's Avatar
To clarify...I do have a aftermarket aux cooler.
I have talked to several companys...they all agree that the stock STR from GM is about 1.4-1.5 and 1200 rpms stall for my body style. I'll be stepping up to roughly 2.3 and 3k.
Old Sep 25, 2006 | 09:06 PM
TXsilverado's Avatar
any mod that makes you faster puts more stress on everything
Old Sep 25, 2006 | 10:03 PM
true but you shouldnt worry too much. FWIW, my trans has 86k on it and its slipping some but holding strong. was pure stock until about 70k then i got my hands on it. before, it was used for towing but no more. i have run my TC, shift kit, servo, and cooler for a while now and its still holding up. ive been driving it like a baby though recently because i dont want something to go clunck clunck pop.... rev rev rev....
Old Sep 27, 2006 | 11:46 AM
gnd111's Avatar
higher stall means more stress...
