DJM CALMAX 2/4 Help
Hey I was wondering if anyone has had a DJM CALMAX kit installedd before? The reason why i am asking is because thats what i put on my truck and it sits crooked. Passenger side is about 2 to 3 inches higher and looks bad from behind not to mention bugs the hell out of me. When i call DJM i pretty much get the run around and no answers. So anyone have any ideas????
Did you take actual measurements to determine the difference in height.
A lot of trucks sit crooked at the stock height - mine does. It's about 3/4" lower on the driver's side. It would be very pronounced if it were lowered. This is probably what you are seeing.
I heard that they had a lean too but it is really noticeable and looks pretty bad. Drivers side looks great passenger looks like i need to take the rear down a couple inches. Well my buddies installed it for me and failed to take the measurements. I just need a way to correct it. I am not afraid to spend money to fix it i just need to know how.
Its the Chevy lean. Its because a lot of the weight is on the drivers side, fuel tank, battery, etc. I usually don't have more than a half a tank in mine because it leans like that too, although I don't think its as bad. (btw, I have the DJM 4/6 kit) A lot have complained of noticing it after the truck is lowered. Hopefully someone will have an answer as how to fix it for ya.
Well i read this and maybe a new drivers side coil will do the trick I have stock ones now.http://www.automotiveforums.com/vbul...d.php?t=346539 It may work or maybe shims...
Originally Posted by O3GMC
Yes they have a lean but 2-3 inches seems extreme to me....I'd expect 1" at most (mines about 3/4" with a 2-4 drop )
