disapointed with 4.10 gears need help why
Old Feb 4, 2010 | 08:51 PM
  #21
budhayes3's Avatar
PT's Slowest Truck
You should be able to launch better with the 4.10's, but you'll like it more up top with the 3.73's. If you match the combo of cam/heads, torque converter, and gears, I think you'll be happier. If it were me, and I already had 4.10's, I'd upgrade the camshaft to something that would work with about a 3k converter, if there's PCM software available that could support those mods (not sure what's available for the SBC Vortec's). As a comparison, I used to have a 71 Camaro with a 350, DartII heads, Comp 292 Magnum cam, 3k converter, and 4.10's, and I felt that the combo was perfect. It launched like a beast, and I had it at 6800 rpm in 3rd gear and it was still pulling when I ran out of road. I had the car and drove it when I was 17-19 years old and never got it to the track unfortunately, but I was very happy with the combo. I know you can't compare a car and a truck, but hopefully this info helps a little bit.
Old Feb 5, 2010 | 12:55 PM
  #22
bolikes2skate's Avatar
**** my 3:42 to 4:10 swap made a pretty big differance for my truck.. maybe cuz its a reg cab and lighter then most of yalls ext cabs. n for me the costum tune was the biggest difference not the gear
Old Feb 5, 2010 | 01:08 PM
  #23
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by lady3bglover
If you step to a ECM from a heavier model truck of the same make/yr you should be ok. The computer thinks it's going to pull a heavier vehicle, but it's not, and this is where you can make up a little ground. Local salvage yard here had a Tahoe ECM for my 1500 for $40. I took it to Flaco for a tune and it's perfect.
Umm, right. I'd love to know where you heard that.
Raggedz71
Jul 29, 2016 10:20 AM
silverstreak07
Jun 28, 2016 06:29 PM
livefast1
Sep 25, 2015 07:31 PM
1bad2k
Sep 7, 2015 09:26 PM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
