difference between "z" pack and borg/warner clutches
Old Mar 19, 2006 | 06:03 PM
Default difference between "z" pack and borg/warner clutches
ok, i know the z pack is metal but i was wondering what kind of durability and performance issues/differences there are between the two. any help is greatly appreciated. thanks
Bryan
Old Mar 19, 2006 | 06:53 PM
James B.'s Avatar
The z-pak has single-sided clutches. That menas that every single piece is exposed steel on one side, clutch material on the other. The theory is that this configuration allows the clutch pack to handle more torque becuase it can more evenly absorb and dissipate the heat generated. A conventional clutch pack has plates splined to the hub that have clutch material on both sides, and steel plates splined to the drum.
Old Mar 19, 2006 | 07:07 PM
well is that theory true? one tranny shop told me not to use the z pack cuz they get bent
Old Mar 19, 2006 | 07:12 PM
FLT's Avatar
FLT
FormerVendor
I think it's a POS. Yes more frictions with even thinner steels. Ones I've pulled out have all been warped. I believe in a good 8-pack 3-4.
Old Mar 19, 2006 | 08:34 PM
TeamTripp's Avatar
I'm on board with da wrench. The best frictions in the world won't last if you can't get rid of heat. The thicker steels, as found it conventional clutch setups, do an excellent job of dissapating heat. I use 8 Borg Warners w/ thick steels.
Texas5.3_1251
Mar 5, 2016 08:10 PM
Jordan927
Nov 10, 2015 02:47 AM
kmcn47
Sep 17, 2015 01:12 AM
fortune46x
Sep 16, 2015 08:18 AM
sprayed99
Sep 14, 2015 12:36 PM
