difference between 2wd/4wd 4l60e
Old Dec 1, 2010 | 03:47 AM
Raven02TA's Avatar
Default difference between 2wd/4wd 4l60e
Have a 2004 tahoe 4wd. transmission bit the dust.
need to know the difference between the 2wd and 4wd transmissions. (other than the T-case obviously)
i mean is there an output shaft difference or bellhousing/input shaft different.
or if i were to buy a 2wd trans. would it be as simple as swapping my t-case/tail shaft to the 2wd transmission and install it?
Old Dec 1, 2010 | 07:03 AM
2BFAST's Avatar
The difference is the output shaft to accomodate the t-case. In order to make a 2wd a 4wd you will have to disassemble the trans and swap shafts. If you are going through that much trouble, might as well build it while ur there. Be easier to find a 4wd if you want a straight swap
Old Dec 1, 2010 | 08:26 AM
Vince B's Avatar
Thats pretty solid advise above. If you were to take it to a trans shop I would think that they could swap a shaft for you for less than a hundred dollars. Vince
Old Dec 1, 2010 | 06:07 PM
Raven02TA's Avatar
thanks fellas, thats what i needed to know.
zblee
Nov 11, 2015 12:41 AM
Tigger Welder
Oct 1, 2015 08:41 AM
Jake99
Sep 16, 2015 10:14 AM
94f150
Sep 13, 2015 06:39 PM
screaminian47
Sep 7, 2015 08:20 PM
