desperate with 4/6 drop on silverado 00 2WD
Old Dec 6, 2010 | 04:31 PM
  #21
00Silv4.8's Avatar
Anyone think about the bump stops on the front? I didnt see if anyone asked if the control arms were factory. If so, its sitting on the bump stop, pull it and get an aftermarket or cut yours down
Old Dec 6, 2010 | 04:32 PM
  #22
dlt76028's Avatar
looking at those other pics, the passenger side is level but the rear driver is lower. that is extremely common in these trucks, its called chevy lean, because the gas tank and battery are on that side.
Old Dec 6, 2010 | 04:34 PM
  #23
picobas's Avatar
Registered User
Originally Posted by dlt76028
if i was you, i'd take the front coil springs out and cut 1/2 a coil off and be done. that would put you level or .5" lower in the front.
I will soon buy the final tires & rims , look how it looks already without thinking of the adjustement , if it look potentialy satisfiable I will choose this solution , but I strongly think I will like to go lower than that because I think it won't look low enough ..
Old Dec 6, 2010 | 04:54 PM
  #24
Bigredmariner's Avatar
Originally Posted by picobas
sorry language barrier , what do you mean by settle some , you mean the tires will touch ? peace
The coil springs have a tendency to drop more after they have been installed for a few weeks.
Yeah good point, I had to trim mine a good bit because I was too cheap to get the correct replacement bump stops. That could be holding the front end up for sure.
Old Dec 6, 2010 | 11:42 PM
  #25
bluebommer07's Avatar
leave like that looks badass
Old Dec 20, 2010 | 06:30 AM
  #26
picobas's Avatar
Registered User
Thanks for all your replies guys ,
I drove close to 6or 700 hundred miles with it , so no luck about the coils settling up or so , i will check at my local garage for the bumpstop thing to see what we can make , if not I will just ordered a pair of 3"in lowered coils for the front so it will be settled , I really appreciate your answers and will let you know about once work is done with it , Peace
pjb1972
Sep 17, 2015 02:06 PM
GMCSIERRA5.3
Aug 7, 2015 01:50 AM
Ketis
Jul 23, 2015 12:37 PM
85SS/85GN
Jul 22, 2015 12:48 PM
