desperate with 4/6 drop on silverado 00 2WD
Hey guys
I have a Silverado 1500 2WD 1999 single cab with a fresh made 4/6 DJM drop kit with stock wheels , I must say I am not satisified at all by the looks & will do anything to change it , and the front is higher than the back for unknown reasons to me ! please let me know what can I do (without changing kits or spending too much to adjust the front and the back and to lower it another 2 inches , your help is highly appreciated , thanks !!
like mentioned above, make sure the front springs are completely in the pocket. they will also settle 1/2" to 3/4" over the first week of use. if the truck had a 2" drop shackle to level out the stock ride height it will need to go back to the stock shackle.
if you want the rear end higher, you can put a lift shackle in. if you want the front lower you can trim the springs a little.
Thanks so much for your comments guys , here is a few pics of the truck as I think it is the best way to check ! sorry I took some times to come back but I've been away for a week , here are the pics ...
http://www.auctionzealot.com/members..._7965628_n.jpg
