Which deep transmission pan for 4l60?
I put one from Mag-Hytec,Its aluminum Finned,It holds 3 Qts More than The stock one,It has a Magnetic drain Plug,And My Trans. now runs 10-15 Degrees Cooler.I like it so much that I put on there Rear Diff. Cover.Hope this helps.
just throwing it out there, if you are are doing it to cool your tranny temps down, go ahead and get the tru-cool 40k, believe that thing is going to cool you down way low without needing a deep tranny pan... it may even be cheaper aswell... unless you are doing it for some odd reason...
Resident Retard
