crush sleeve question
Old Oct 22, 2012 | 07:29 PM
04Hall's Avatar
Default crush sleeve question
I may have over tightened the crush sleeve, I didn't read far enough ahead while installing my 4.11s and tightened the **** out of the pinion nut to seat the bearings and races, I did how ever end up with a good preload and gear mesh pattern. I've drove the truck for about 60 miles with no problems or noises. When I drove 20 miles and parked it the housing by the pinion was hot to the touch but I'm assuming it would be, its been driven a few more times back and forth to work about 10 miles each way and the heat is gone. Should I be worried about this or think all is well?
Old Oct 22, 2012 | 07:39 PM
04Hall's Avatar
Just wondering if I would notice its not correct right away, or if this would be a slow killer. Wanting to know what I need to be looking for and checking as I drive and break it in.
Old Oct 22, 2012 | 07:57 PM
dirt track racer 81's Avatar
Does it whine? If not dont worry about it.. I've done 50+ gear swaps and always reused the factory crush sleeve..
Old Oct 22, 2012 | 08:07 PM
04Hall's Avatar
No whine, no odd noises at all! Sounds like I've done nothing at all to it. How long to you recommend waiting before giving it a little throttle?
Old Oct 22, 2012 | 08:31 PM
whitedakota's Avatar
I'd let it bump.. I drove mine to work almost a week just to give them a few good heat cycles. 30 mile round trip. Then Friday after work let it bump!
Old Oct 22, 2012 | 09:19 PM
Ferocity02's Avatar
Ditto, wouldn't worry about it if it's all good. Baby it for 500 miles, change the oil and inspect the gears, then go to town. I reused my crush sleeve because the new one wouldn't crush, even with my 500 ft-lb impact gun.
Old Oct 22, 2012 | 10:55 PM
SLCviaAK's Avatar
If you measured the turning torque of the pinion, and that preload was correct, then you're just fine.
Old Oct 22, 2012 | 11:42 PM
Atomic's Avatar
I have a gauge for that
I reuse the stock one as well. When my 250lb *** couldnt crush a new sleeve hanging on a 5ft bar I said f it.
Old Oct 23, 2012 | 06:07 AM
04Hall's Avatar
I'm 150 soaking wet and I crushed the **** out of it! I used pipe wrench to hold yoke and 12" breaker bar with another 12" pipe I had laying around. It took all I had but it crushed finally.
Old Oct 23, 2012 | 06:08 AM
04Hall's Avatar
I'm curious to see what I find when I open it back up
