cruise control and TCC
Old Jul 21, 2008 | 12:25 PM
  #21
Wilde Racing's Avatar
How do I change this text
Originally Posted by 1BADC10
I don't know that to be true as the ONLY variable to determine releasing the TC. This is just one dependency (variable) that must be satisfied in order for the PCM to unlock the TC. The final variable that determines if the TC is released is actual speed (mph) given the actual gear the trans is in. This is where the release cells of the apply/release tables come in.
4.8T... post a screenshot of your TCC apply/release (normal, hot, and performance), duty cycle, and release TPS% tables. Take note of what your release speed cells for 4th gear look like. Log a few runs decelerating normally & w/ cruise engaged. Watch the speed, and TCC lockup command using VCM Scanner. I don't have lockup issues like this with my setup ('00 PCM & built 65e w/ Yank SS3200).
*edit*
Found this from HPT Support:
TCC Release TPS - This table is the required TPS at a certain speed and gear to release the TCC.
Not the only variable, but one of them for sure. I tried changing the low side of the tcc control table to keep the converter locked. No mater what value I entered, 0= tps always ment no tcc apply. I'm kinda wondering what would be so great about locking the converter under decel anyway.... other than fixing the pesky light throttle unlock feel.
If the converter in unlocking under throttle, check these three things.
You are not comanding the tcc to unlock.
You dont have a dtc that causes the converter to unlock.
It's really is the converter that you are feeling.
Old Jul 21, 2008 | 12:36 PM
  #22
TURBHOE's Avatar
mines not the converter. its something else. i logged it i'll see if i can find the part of the log and post it.
Old Jul 21, 2008 | 03:18 PM
  #23
TURBHOE's Avatar
very weird. the rise in map and throttle was going back up the hil. then when it tops out it lets off the throttle and jerks around. it feels like when i let off it slows down too fast. and the computer doesn't like it. so it hits the gas again.
Old Jul 21, 2008 | 05:15 PM
  #24
Well it looks like you are in cl at the converter flare so no dfco...
You should log the "tcc pwm" pid as well as the "tcc slip RPM pid" I think it is a misfire..
Old Jul 22, 2008 | 07:11 AM
  #25
TURBHOE's Avatar
maybe from big *** injectors??
Old Jul 22, 2008 | 12:14 PM
  #26
log those pids I posted above and report back...
Old Jul 22, 2008 | 12:20 PM
  #27
TURBHOE's Avatar
will do.
Avalanche2002
Nov 30, 2015 07:31 AM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
Chevy305
Sep 28, 2015 09:21 PM
