Correct me if I am wrong... 4L80E
Correct me if im wrong, but I have a 00 RCSB silv 2wd with a 02 cadi esc LQ9, to put a used stock 4L80E tranny and stock 4L80E TQ converter all I would have to do is reprogram the tranny computer, modify the crossmember, extend the rear tranny fluid line, get an adapter for the electric plugs, and change the yoke to a 13##? so it will mount to my stock drive shaft. Am I missing anything?
You will also need an 80e flywheel with a stock converter. there is no tcm. everything is controlled in the pcm, but it would have to be adjusted. That or do the relay mod which you can find info on here.
Everything said above is about correct. dont foreget the flexplate. The connectors are the same, you can repin them multiple different ways depending on how you want to control it. The segment swap method would be the better method as far as a stock form setup. The relay method is quick and works, but both methods will need retuning to change tranny specs.
