Converting Z71 4x4 to 2WD stance
Old Mar 30, 2008 | 03:38 PM
OneBadSSS's Avatar
Default Converting Z71 4x4 to 2WD stance
I want to lower my truck a bit but not do a full blown aftermarket suspension kit. I really like the stance of the stock 2wd trucks and I was wondering what all I would need besides 2wd u-bolts, removing the lift blocks and buying 2wd drive shocks in order to get my truck down to that stance? TIA for any help and if anyone has the p/n's for the oem parts I would need to buy I'd greatly appreciate them, thanks!
Old Mar 30, 2008 | 03:45 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
What are you going to do about the front?
You can untwist the torsions a little but then it will rest hard on the stops...unless you cut them and then it will be a little (not bad) loose.
Old Mar 30, 2008 | 04:30 PM
OneBadSSS's Avatar
I have no idea what I need to do to the front end, that's why I'm calling on the experts to point me in the right direction!
Old Mar 30, 2008 | 04:42 PM
trever1t's Avatar
Most of us will recommend spindles but they'll require 17" wheels, minimum. If you're just going to take out the block and want a level stance you can probably get away with just de-twisting the torsions an inch.
Old Mar 30, 2008 | 07:50 PM
KevinF56's Avatar
do you want a stock height 2wd height? if so just pull out the lift blocks and de-crank the torsion bars a little.
Old Mar 30, 2008 | 08:10 PM
jkwalkercchs's Avatar
put green keys in it if our keys lift the 2500hds then theres should drop our 1500 trucks
Old Mar 30, 2008 | 09:14 PM
OneBadSSS's Avatar
So you're saying I could just swap in a set of 2500HD torsion keys to lower the front in addition to removing the rear lift blocks and switching to 2WD U-Bolts in the rear and that should give me the stock 2WD stance?
Old Mar 30, 2008 | 09:15 PM
OneBadSSS's Avatar
Is de-cranking the torsion bars going to have any adverse effect on drivability and component longevity in the front end?
Old Mar 30, 2008 | 09:17 PM
trever1t's Avatar
not if only a little bit, like an inch. Mine is down some, handles pretty good but i need to get rid of those stock shocks.
Old Mar 30, 2008 | 10:31 PM
re key it so it rides stock and not bouncing you around like a lowrider in a snoop doggg video
