Converting Z71 4x4 to 2WD stance
I want to lower my truck a bit but not do a full blown aftermarket suspension kit. I really like the stance of the stock 2wd trucks and I was wondering what all I would need besides 2wd u-bolts, removing the lift blocks and buying 2wd drive shocks in order to get my truck down to that stance? TIA for any help and if anyone has the p/n's for the oem parts I would need to buy I'd greatly appreciate them, thanks!
What are you going to do about the front?
You can untwist the torsions a little but then it will rest hard on the stops...unless you cut them and then it will be a little (not bad) loose.
Most of us will recommend spindles but they'll require 17" wheels, minimum. If you're just going to take out the block and want a level stance you can probably get away with just de-twisting the torsions an inch.
So you're saying I could just swap in a set of 2500HD torsion keys to lower the front in addition to removing the rear lift blocks and switching to 2WD U-Bolts in the rear and that should give me the stock 2WD stance?
