Converting a yukon denali from AWD to 2/4wheel drive
Old Nov 12, 2012 | 12:01 PM
Yukon04's Avatar
Default Converting a yukon denali from AWD to 2/4wheel drive
Is this just as simple as replacing the transfer case and front shaft or do I need to replace my front diff as well? Also is it possible to have a operational 2/4 electric shift or do I need to get a manual transfer case and just crawl underneath and click it in when I want to go 4wd.
Old Dec 2, 2012 | 01:31 PM
Chevy_freak's Avatar
Need to swap the front axle for one with a disconnect and maybe add the wiring for it. May need to add the wiring along with the switch inside the cab, and find a transfercase with the actuator on it.
The BCM may need to be programmed to make the shift actuator work.
If I get around to doing it, I was going to find a totaled 4wd yukon and swap everything. There were some with a full-time 4wd system also, just had a hi-lo range unlike the AWD cases. So double check you know what you're getting.
Old Dec 13, 2012 | 09:38 PM
Yukon04's Avatar
I found a manual transfer case and I swapped it and the shaft and its a done deal. I have been driving it for several hundred miles no issue, Should I go ahead and swap the axle too though? I have it from that same doner truck.
Old Dec 14, 2012 | 11:05 PM
By running the non-disconnect front axle, youre turning the front driveshaft all the time. If you can live with that, then you should be fine.
Oobray
Jun 13, 2022 03:38 AM
chacho44
Aug 3, 2015 04:07 PM
walledition
Jul 29, 2015 08:54 PM
Denali man
Jul 19, 2015 03:52 PM
350SS
Jul 11, 2015 12:34 PM
