converting drive by wire to cable?
Old Sep 18, 2007 | 09:09 AM
tuckin62's Avatar
Default converting drive by wire to cable?
1st off this is a great forum now my question is that i have a 04 5.3 and 4l60e out of a tahoe and its drive by wire, i was going to put a stand alone engine management system on it but im considering going to carberator, i can convert the engine real easy but what about the tranny, i dont want to put a comp-u-shift on it, is there a way to convert it to cable?
Old Sep 18, 2007 | 10:12 AM
Nick™'s Avatar
700r4
Old Sep 18, 2007 | 10:16 AM
tuckin62's Avatar
what about the 700r4, i dont want to change the tranny, if i have to do that i will go efi
Old Sep 18, 2007 | 11:07 AM
kbracing96's Avatar
The PCM uses a lot of info from the engine airflow to determine shift pressures and other variables in the trans, it you go carb, then you will probable have to ditch the stock pcm and get a MSd or something for the ignition and some sort of controller box for the trany. Not really anyway around it that I can see.
Edit: After rereading your post, there is no way I know of to make a 4L60 a "manually" controlled trany. It need something to control it. All the shifting is done with solenoids in the VB.
ARC
57
Feb 21, 2022 10:54 AM
greedygenius
Sep 3, 2015 06:51 AM
TimDave217
Aug 24, 2015 04:38 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
