Converter won't seat onto input shaft..
Old Mar 28, 2017 | 07:47 PM
03blksrt-4's Avatar
Default Converter won't seat onto input shaft..
So I bought a coan triple disk converter for my 4l80e. If I leave the oring on the input shaft I can't get the converter to seat all the way in.. I've tried and tried.
remove the oring and it goes right in, however I believe it has to be there.
any help is appreciated....
This is the inside of the coan converter
Old Mar 28, 2017 | 07:51 PM
03sierraslt's Avatar
I forget what it's called. They make a wax like substance that you can put on the oring to protect it during install, it's a tight fit and you don't want to damage it.
Old Mar 28, 2017 | 08:37 PM
montecarloss's Avatar
LS ADDICT/BUILDER
apply a little petroleum jelly on the oring and apply some pressure while rotating the converter. a lot of triple disk converters are really tight and can be a pain to fully seat fully.
Old Mar 28, 2017 | 08:54 PM
2002_Z28_Six_Speed's Avatar
Lubegard Dr. Tranny Assemblee Goo 19250 - Transmission Assembly Lube | O'Reilly Auto Parts
Old Mar 28, 2017 | 11:04 PM
Vortec350ss's Avatar
I found that when compared to a stock input shaft the groove for the o ring was too small this stretching it out and making the outside diameter larger than the stock o ring on the stock input shaft. I ended up using one that's a **** hair thinner than what was supplied and it worked beautifully.
Old Mar 29, 2017 | 12:02 AM
Atomic's Avatar
I have a gauge for that
I haven't had tcc lockup in years and I suspect this is why.
Old Mar 29, 2017 | 05:51 AM
CF7GO's Avatar
Compared to an aftermarket input shaft???
Old Mar 29, 2017 | 04:35 PM
GMCtrk's Avatar
Hit the hub with a rubber mallet while spinning the converter. It will seat eventually.
Old Mar 30, 2017 | 09:39 AM
03blksrt-4's Avatar
I ended up using a little lube on the o-ring and worked it for 20 plus minutes. finally got it in. Thanks for the advice.
Old Apr 3, 2017 | 06:07 AM
Mark Buck's Avatar
Sonnax slippery stick or Door-ease lube stick
