Converter stall speed
Old May 30, 2013 | 02:43 PM
1duffman's Avatar
Default Converter stall speed
Any one know what the stall speed is on a GM81 torque converter and a GM82 torque converter for a 4L80E? All I've found out so far is 81 is low stall and 82 is high stall haven't found out the speed yet, wonderin if you guys knew...
Old May 30, 2013 | 05:01 PM
Circle-D's Avatar
Former Vendor
Really depends on input power and weight. But I would say a 81 is 1500-2000 and an 82 is 2000-2500 range.
Chris
Old May 30, 2013 | 10:34 PM
1duffman's Avatar
Thats kinda what I've figured out was somethin in that range for them. I know they use the 80E in diesel Chevs also to match the torque curve. So from what I figure the 81 was for the diesels and the 82 was for the gas. I'm figuring an 82 for my swap, 96 Tahoe 4dr with an LQ4. From what I've researched for with the torque curve of my basically stock engine the 82 would be the best bet. Do you agree? Do you think a set of 806's and a .030 overbore would change that curve much?
Old May 31, 2013 | 10:50 AM
Circle-D's Avatar
Former Vendor
I would definitely do the 82.
Chris
Old May 31, 2013 | 12:48 PM
1duffman's Avatar
Thank you
Old May 31, 2013 | 01:06 PM
nonnieselman's Avatar
im running the 82 style in mine and towing a trailer its nothing to get the rpms to sit at 3000 while accelerating pulling a trailer. its pretty dang loose for a stock converter.
Old May 31, 2013 | 03:05 PM
Circle-D's Avatar
Former Vendor
Wow, that is looser that I would of thought. What are your gears and boost level at 3K?
Chris
Old May 31, 2013 | 03:15 PM
Yea i know.. its crazy, it gets in boost pretty quick with a nice load
5-6psi
3.42
265/65/17
towing about 4800#
Old May 31, 2013 | 04:22 PM
Circle-D's Avatar
Former Vendor
5-6psi
3.42
265/65/17
towing about 4800#
Impressive... You make some great power down low.
Chris
Old May 31, 2013 | 04:36 PM
Ill send you a video next time i tow something haha..
i want a lighter/stronger/more effecient converter before i make alot of power for it.. i dont trust this $90 Stock reman to no ballon or anything silly.
