converter question
Old Jun 22, 2009 | 11:12 AM
terravast4's Avatar
Default converter question
I was wondering if every time you add mods if it changes the way your converter acts? If you added another 50-100 hp would it cause the converter to flash higher? Do the mods make it feel looser?
Old Jun 22, 2009 | 11:28 AM
00ChevyScott's Avatar
Wearin' da big hat
You are correct.
Old Jun 22, 2009 | 11:48 AM
terravast4's Avatar
Thanks.
Old Jun 22, 2009 | 01:43 PM
Circle-D's Avatar
Former Vendor
Correct the more power you add the the engine, the higher the converter will flash/stall. There is also the possibility of changing the torque curve and lowering the stall. If you have a stock converter and add a different cam with a higher torque range, it might footbrake a little tighter because you will have less power down low than with the factory cam.
Chris
GXPJAY
Feb 13, 2022 08:15 AM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
