Converter question
Old Apr 26, 2008 | 08:57 AM
1BAD73's Avatar
Default Converter question
Last week I installed a used TCI 3500 converter in my 00 RCSB. The truck has 140,000 miles and the trans is otherwise bone stock. The converter worked ok for the first 250 miles, the only problem it had was it would vibrate/slightly grind when locking up. Yesterday the converter decided not to lock up at all. My trucks message center went red and said Trans hot... idle truck. When I installed the converter, I put a large tranny cooler in front of the radiator. My questions are: Which tranny cooler line does everyone tie into for their aftermarket coolers : top or bottom?
Do you think the converter is junk?
Is this the problem everyone else has had with the lockup on TCI converters?
Your help is much appreciated.
Old Apr 26, 2008 | 09:31 AM
00ChevyScott's Avatar
Wearin' da big hat
Converter is probably junk, alot of people have problems with TCI man.
Get a yank or Vig
Old Apr 26, 2008 | 10:29 AM
1989k1500's Avatar
Yea everyone seems to have problems with TCI convertors not locking up.
Its also not good that you put that big *** stall in there with no shift kit or anything.
Edit: You also need to get the truck tuned for the converter.
Old Apr 26, 2008 | 10:45 AM
Truckshop's Avatar
get it tuned so it will lock up properly then it should quit overheating.
Old Apr 26, 2008 | 11:38 AM
Klive's Avatar
Banned
definatly suspect that the TCI has taken a dump....
Old Apr 26, 2008 | 12:24 PM
built408's Avatar
TCI's are junk.
Old Apr 26, 2008 | 07:51 PM
Wide Open's Avatar
I destroyed a 10" TCI converter and several supposedly street/strip built transmissions with a 406 SBC. I don't think I would buy another TCI product. Other than their aluminum deep pan which I like ok.
Old Apr 26, 2008 | 08:08 PM
Mangled03gmc's Avatar
Baltimore Whore
TCI verters don't seem to do well in the 4l60's for some reason, I would try to find a Yank PI or older fuddle....
John
Old Apr 26, 2008 | 08:20 PM
Banned
yea get a pi and also a deep pan
GXPJAY
Feb 13, 2022 08:15 AM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
