Converter problem?
Old May 5, 2006 | 08:45 AM
Bad_Apple's Avatar
Heck with my Yank 2600 TT brake stall.. Was about 2000 rpm's before it would start spinning the tires. So I would say you don't have a 2600.
Old May 5, 2006 | 08:47 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
With brake fully engaged i cant even get the rear tires to spin. Fully being the key word, when simply braking they spin like a ****.
Old May 5, 2006 | 09:57 AM
Bad_Apple's Avatar
OOO Well I mean with my brake mashed to the floor my truck would start spinning at 2000 rpm's with my 2600 TT
Old May 5, 2006 | 12:52 PM
litreddevil's Avatar
Banned
if u can not spin the tires @ all then something else is wrong check fuel pressure and then check converters to see if they may b stoped up
Old May 6, 2006 | 12:50 AM
maybe you just have really good brakes?
Old May 6, 2006 | 01:17 AM
TouchOfEvil04's Avatar
I ahve a TT2600 in my truck and i can press the brakes down fully and it stalls to 2600 a hair too much gas and it start boilin them down.Just a little brake and god watch the smoke show begin at about 2000rpms.
Old May 6, 2006 | 01:40 AM
sweet
Old May 6, 2006 | 07:59 AM
trever1t's Avatar
So is it good brakes or abnormal for me to be able to hold it at 2600 and not spin the tires?
Under normal very hard braking it will burn the tires off but if i hold the brake and put it in Neutral and rev the engine the brake will drop all the way and then I can hold the tires from spinning.
Can someone else please try this with a TT3000 and tell me what it does for you?
Old May 7, 2006 | 12:28 AM
isnt that bad for your trans? are you talking stomp the break, drop to neutral, holding the break, rev the engine to 3000? i guess, and put it into gear again? all from a stop? sounds like a good way to mess stuff up but i guess if you can convince someone with a built 60 then maybe, or maybe i just dont get what your saying i dont have a yank though so im no use
Old May 7, 2006 | 01:18 AM
I woudn't keep tryin the neutral/brake/rev thing very much bro thats gonna mess stuff up fast.
Your holding power on that stall has alot to do with how much brake power you ahve as well as your power you make and how well your tires can hold the road.Its not as simple as just saying i got a 3000 stall.
If you can't get your brakes and tires to hold the power then it won't stall that high.
I have a TT2600 i can give it brake to the floor and rev it to 2600 like it says but a blip more gas and it smokes them down like crazy.
I'm sure you could try the neutral/throw it into gear method but i woudn't recommend it...at least not if you want your tranny to last.
