Compatible 4l60es
Old Dec 22, 2018 | 08:52 PM
Mcat069's Avatar
Default Compatible 4l60es
So I recently purchased an 03 4x4 s10 crew cab LS v6/4l60e with 122k on it. The transmission is throwing P0894 and the rpms jump in 3rd or 4th gear 200-300. I planned on going to the local wrench-a-part and find get another transmission. I know I need to find one out of a 4x4, but what else needs to be the same? Will any 4x4 4l60e work? Thank you in advance for any guidance.
Old Dec 22, 2018 | 09:52 PM
FFDP's Avatar
Should be pretty safe finding one from the early to mid 2000's.
Old Dec 24, 2018 | 12:53 PM
MaroonMonsterLS1's Avatar
input shaft and bellhousing. If they are the same, and it's 4x4...it will interchange. 97+
Old Dec 24, 2018 | 12:56 PM
Mcat069's Avatar
Thank you for the replies. I assume the bell housing is different on one matted to a v6 as opposed to a v8?
Old Dec 26, 2018 | 01:05 AM
RedXray's Avatar
100% Redneck
There are three different 4L60E transmissions 93-97 with the bell housing cast into the case. The 96-99 (96 and 97 models had some overlap) has a removable bell housing and upgraded electronics. The 2000+ has a longer removable bell housing with an additional engine mounting hole for the LS engines. The bell housing is longer to accept a larger torque converter along with a redesigned input shaft. You're looking for a 2000+ 4L60E from either a V6 or V8. Check and see if you have the top engine mounting hole for the LS (or 4.3) engine.
This will explain the 4L60's in detail...
Old Dec 26, 2018 | 06:08 PM
Mcat069's Avatar
Thank you for the information and the video link. Hopefully this weekend I can go rummage through the wreaking yard and find a suitable replacement.
doublenot
11
Feb 27, 2007 04:48 AM
