Common for verters?
Old Aug 28, 2005 | 03:05 PM
KySilverado's Avatar
Default Common for verters?
I put a PI Vig 2600 in my truck recently. Right after the install best I could get it to brake stall was around 1800 rpm. Now after about a month in the truck it will brake stall to about 2500 rpm. More in line to what I would expect for a 2600. Question is do they require break in. is this normal?
Old Aug 28, 2005 | 04:03 PM
99Silver6.0's Avatar
Its common. They loosen up after you get some miles on them.
Old Aug 28, 2005 | 04:09 PM
Mr. Sandog's Avatar
I've heard that, and I've heard that they tighten up over time. Go figure.
Old Aug 28, 2005 | 04:11 PM
See, Ive read the same things. I figured I was safe to say it would loosen a bit.
Old Aug 28, 2005 | 04:15 PM
Mr. Sandog's Avatar
For example, I've heard the Yanks start off loose and tighten up over time.
Old Aug 28, 2005 | 04:20 PM
It must vary from verter buidler to buidler.
Old Aug 28, 2005 | 05:20 PM
Can be traced to track times also. Right after the install a trip to the track did not result in improved 60' times. 2.0X. Same as the factory verter. About 3 wks ago saw 1.9X 60' at STS in 95+ heat. Probably going to the track this weekend maybe I'll see the 1.8X 60' I was expecting with the verter.
Old Aug 28, 2005 | 07:46 PM
KLUG'S SS's Avatar
FormerVendor
That is exactly what my Yank tt3000 did, when I first had it installed it felt extremely loose and had thought that maybe they had sent me a higher stall than I ordered but it has tightened up now and I barely even notice it is there under normal driving.
Old Aug 28, 2005 | 08:25 PM
Seems my truck and mods don't follow the beat and path. Lets see, the things that come to mind.
Verter clearance to flexplate both stock and aftermarket at about 5/16" when everyone says should be about an 1/8 to 3/16"
Loss of boost after cam install. 2.5 to 3psi. Others lost little to none.
Now my verter seems to go oposite of common break in... or at least a Yank.
Old Aug 28, 2005 | 11:03 PM
I believe they tell you to have a 150 mile break in period before you really get in to it.
