Common for verters?
I put a PI Vig 2600 in my truck recently. Right after the install best I could get it to brake stall was around 1800 rpm. Now after about a month in the truck it will brake stall to about 2500 rpm. More in line to what I would expect for a 2600. Question is do they require break in. is this normal?
Originally Posted by Naked AV
I've heard that, and I've heard that they tighten up over time. Go figure.
Can be traced to track times also. Right after the install a trip to the track did not result in improved 60' times. 2.0X. Same as the factory verter. About 3 wks ago saw 1.9X 60' at STS in 95+ heat. Probably going to the track this weekend maybe I'll see the 1.8X 60' I was expecting with the verter.
For example, I've heard the Yanks start off loose and tighten up over time.
Seems my truck and mods don't follow the beat and path. Lets see, the things that come to mind.
Verter clearance to flexplate both stock and aftermarket at about 5/16" when everyone says should be about an 1/8 to 3/16"
Loss of boost after cam install. 2.5 to 3psi. Others lost little to none.
Now my verter seems to go oposite of common break in... or at least a Yank.
