Clunk sound on park to reverse? help
Old May 1, 2007 | 02:20 AM
icedenali's Avatar
Default Clunk sound on park to reverse? help
I hear Clunk underneath front between park and reverse.
took look at u joint they rust up. how do i check if that is the problem
maybe because i have build tranny and maybe that can be it little too hard. but it only does it on fresh start in the morning.
Old May 1, 2007 | 04:54 AM
04GIBBS's Avatar
I would go ahead and replace the U joints, usually the clunking is a sign of a bad U joint
Old May 1, 2007 | 10:31 AM
icedenali's Avatar
there are 4 u joints in the truck, do i have to replace the all 4 or just ones in front.?
Old May 1, 2007 | 10:34 AM
LesPaul's Avatar
i would say its coming from your t-case and its actually perfectly normal... Or says GM anyway
Old May 1, 2007 | 10:35 AM
04GIBBS's Avatar
I would check and grease the ones that are fine and replace all the others. If you can change them yourself and they have a lot of miles on them then I would replace all 4 of them.
Old May 1, 2007 | 04:56 PM
icedenali's Avatar
i only have 50,000 miles on the car.
i'm gonna grease it first and see what happens.
i was thinking first u joint out from tranny front.
will update it.
Old May 1, 2007 | 06:49 PM
04GIBBS's Avatar
Ahh yes I agree with you then change the front and grease the rest
Old May 3, 2007 | 09:23 PM
icedenali's Avatar
well, i got underneath the truck today to change seal.
two things that i notice.
i didnt loose that much oil.
but i lost oil before i'm gonna flush the transfer case oil and change it.
Actually My clunkin sound went away. i guess it was seal problem.
Blwn99x
Mar 24, 2023 11:14 AM
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Rockrz
Sep 29, 2015 09:07 AM
