Circle D Converter First Impression
I installed the 278mm, 3-3200 in my 4L60E. Trans has the HD2 kit and Oregon Perf. billet servos in it along with TruCool 40k cooler. I haven't run it hard yet as it's still in the break-in period.
Hard to believe how far converter technology has come! Quite impressive I might say! Kudos to Chris at CD who made the recommendation. You nailed it!
Truck is a 2000 Silverado ECSB 5.3 4x4 currently running the stock tune with 4.56's and 34" tires. I'm going to do some data logging and adjust the LFT's for efficiency before I reinstall my Predator performance tune.
Other than WOW!!! I feel like putting a line lock on this thing would be cool, LMAO!!
Has made my truck everything it should have been from the factory.
Satisfied Customer....
LMAO!! My thinking exactly!! But I swear for the life of me, I can't locat the pamphlet that came wiht the converter right now, but I swear I remember reading in "the library" that CD recommended 150 mile break in period?? I thought it had something to do with the lockup clutch linings/surfaces mating...maybe I'm confused. Tell me I'm wrong.
V1
V1
I had same converter, loved it! I installed it and drove around the block twice, checked fluid and left some nice black lines down the street with maybe 4 miles on it. Before the tune though it was locking up at wot in 3rd which made the truck(stock motor at time) a dog, get it tuned ASAP!
If it's not tuned for the 'verter, don't be surprised if it throws a shift solenoid DTC and defaults to 3rd gear only when you do try a WOT launch. Also, if you stand on it while it's defaulted to 3rd gear, you might smoke your trans.
Just a heads up.
Just a heads up.
Installed my fresh rebuilt tranny last Friday with circle d 3200, hd2, servos etc.. Checked the fluid and put a new tune on the truck. Several wot runs, 4 hi launches adjusting shift points, timing, and fuel.. Took it to the drag strip the same night for test and tune and cut 2.12, 2.18, 2.16 60 ft times in my heavy crew cab! Hasn't missed a beat! Another very very satisfied customer here also!
