Check my gear setup- PLEASE
Old Jan 17, 2007 | 07:49 AM
KySilverado's Avatar
Originally Posted by Wilde Racing
I know alot of people use inpacts to install their pinion nut, but I wouldn't. if you crush to far there isn't no coming back, with that crush sleeve anyway.
Did you replace the pinion nut?
Yeah, I was apprehensive about using an impact but it was the only way I could get it done. I tried for 2 hours to work something with my limited tools, rear in truck on jackstands, to hold the pinion and put a breaker bar on it to crush the sleeve. I think ideally would be use an impact to pull it up till the bearings touch and finsih it with a breaker bar. I wound up with about 22" inch pound bearing pre-load using the impact but you could very very easily over do it if not taking it easy.
New pinion nut with locktite.
Old Jan 17, 2007 | 07:53 AM
Originally Posted by bluecajun5.3
great job ky!
hopefully it holds up and works out for you.
Hey Thanks! I think its setup correctly so hopefully it will work as it should long term. Can't wait to get it broke in along with getting the front setup.
Old Jan 17, 2007 | 09:08 AM
Wilde Racing's Avatar
How do I change this text
There is a trick I use to hold the pinion, Kinda a pain in the A$$, but, if you thorw the carrier assy back in, then throw the cross shaft in with-out the holding bolt, and rotate the carrier until the cross shaft silds part way out of the carrier and hits the rear-end housing and binds the whole assy up...
Old Jan 17, 2007 | 10:21 AM
There is a trick I use to hole the pinion, Kinda a pain in the A$$, but, if you thorw the carrier assy back in, then throw the cross shaft in with-out the holding bolt, and rotate the carrier until the cross shaft silds part way out of the carrier and hits the rear-end housing and binds the whole assy up...
That would work, good tip!,and I thought about someway to bind it up using the carrier. The Detroit TT doesn't have a cross shaft. Not that I would have thought of it if it had.
Closest I came was getting to some flats on the yoke. My largest adjustable wasn't quite large enough and it was to short to wedge against the ground.
Stainless Works
Apr 10, 2016 04:34 PM
1slwgto
Aug 16, 2015 06:40 PM
Stainless Works
Aug 4, 2015 12:56 PM
iregret
Jul 27, 2015 10:32 PM
