Check my fluid and gasket choice
I got this stuff on a recommendation from the guy at Auto Zone. I know the brand may not be the best but I just want to make sure it’s the right weight and correct modifier. I also got a Fel-Pro gasket, figured that would be fine.
I have an eaton LSD installed. I was told to add the whole bottle of additive (7 ounces)
Is this the right stuff and amounts?
Wearin' da big hat
From Eatons website
Fel Pro gasket should be RDS55028-1
What kind of oil should I use? Can I use synthetics? Do I need a friction additive/modifier?
Eaton Posi units perform best when using GL4 (or better) mineral/petroleum based gear oil. A four ounce bottle of friction additive/modifier is also necessary for optimum performance.
