Causes of Pinion Seal Leak
Old Jul 31, 2006 | 08:56 PM
Last Call's Avatar
TOTM: January 2007
Default Causes of Pinion Seal Leak
I just had my rear end rebuilt with all new bearings, posi, and yukon gears. I have less than 100 miles and it has began leaking from the pinion area.
I want to know what can cause this. Can it be from a bad housing? Drive shaft too long? Im so frustrated right now because until I get it fixed, I cant put the miles on the truck to break the rear end so I can put it on the dyno and have it tuned so I can go past 2500rpm.
Old Jul 31, 2006 | 09:03 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Sorry to hear you're having troubles . Is the shop that installed your LSD and gears going to take care of it?
Old Jul 31, 2006 | 09:06 PM
samdogmx's Avatar
8 Second Club
it could have been installed incorectly or damaged when they put the nut on?
its not hard to swap it out, They should take care of it.
Old Jul 31, 2006 | 09:14 PM
Last Call's Avatar
TOTM: January 2007
YES! The same shop. He is on vacation all week, and then Im on vacation next week. Talk about shitty timing!
Im sure he will take care of it, but I am debating whether to take to driveline specialties and pay out of my own pocket to fix it.
Old Jul 31, 2006 | 09:15 PM
Last Call's Avatar
TOTM: January 2007
I just hope it is not the housing or something else serious.
Old Jul 31, 2006 | 09:19 PM
trever1t's Avatar
Are you willing to wait? Sometimes it's better to cut your losses and move on.
I have a good rear-end specialist (no, not a proctologist ) down here, and his prices are very reasonable.
Old Jul 31, 2006 | 10:30 PM
negativeswitches's Avatar
honestly if you have and 11mm wrench a screwdriver pieve of wood hammer and access to an impact you can easilly do this yourself
or a breaker bar and tq wrench if you can keep the wheels locked e brake or on the ground
Old Aug 2, 2006 | 10:13 AM
You may want to check and make sure your housing is vented well. That also can push fluid out the seal.
Old Aug 2, 2006 | 05:52 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
There is a seal that is crushed in when you cranked down on the nut that holds the pinion yolk on it is easy to get the wrong one or not have it lined up right takes about an hour to fix
Old Aug 2, 2006 | 08:46 PM
Grumpy5.3's Avatar
it could, I say could be leaking out of the yoke if they didnt put any sealer on the splines of the yoke. I have seen this quite often...
Brian
