can you guys help me out here?
Old Mar 28, 2006 | 07:32 PM
Colby 04's Avatar
Default can you guys help me out here?
I'm not getting the response that I had hoped for, nor the answers I need...
https://ls1tech.com/forums/showthread.php?t=476430
Old Mar 28, 2006 | 07:36 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Same kit works for both transmissions I do believe the Z28s have the vette servo already but if nothin else when you get it apart and it doesnt have it order it. Hope this is the answer you are looking for I didnt read the whole thread as it seems it would be pointless.
Old Mar 28, 2006 | 08:54 PM
Colby 04's Avatar
you're killin' me
I'm still lookin' for answers to the following questions:
1) does the Z28 4L60E have a plastic 1st-2nd accumulator piston?
2) will the trailblazer stall converter fit and work the same in the Z28 as it does in our trucks?
Old Mar 28, 2006 | 09:03 PM
TXsilverado's Avatar
their way of thinking is going against everything ive been tought here do shiftkits help or not? which is it
Old Mar 29, 2006 | 12:40 AM
Colby 04's Avatar
Exactly, I was trying to avoid the arguement of "does a shift kit help", I just wanted some questions answered about the f-body 4L60E.....and you see how far that got....
Old Mar 29, 2006 | 07:00 AM
FLT's Avatar
FLT
FormerVendor
If I were you when doing the shift kit I would update all the accumulator pistons. Reason is that they do wear plastic or aluminum and while your there it's cheap security. As far as the tb convertor it will work however it will not be as strong as the vig, etc.These are MO's due to countless rebuilds. Good luck!
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
