Can A Car Posi Fit A Truck?
Old Sep 4, 2006 | 08:32 PM
COLDZ71's Avatar
Default Can A Car Posi Fit A Truck?
Would an aftermarket 8.5 inch Eaton LSD out of an Impala SS fit my truck? They are both 30 spline. Are they interchangeable?
Old Sep 4, 2006 | 08:42 PM
Rhino79's Avatar
9 Second Club
I would think that they would as long as the ring gear size and the splines are the same then it should work. You will need the bearings for the 8.6" rearend though....you can get them at Napa.
Old Sep 4, 2006 | 09:51 PM
COLDZ71's Avatar
Yah it seems as though it should work. I didnt know if there was something that I was overlooking that someone more experienced might know about.
Old Sep 4, 2006 | 10:36 PM
negativeswitches's Avatar
the center chunk and ring and pinion is the same from the s-10 to the f body to the truck
the bearings and axles are different
Old Sep 4, 2006 | 11:01 PM
Rhino79's Avatar
9 Second Club
I thought the cars and s-10's ran 7.5" ring gears?
Old Sep 4, 2006 | 11:14 PM
dirt track racer 81's Avatar
fbody's and s10s are 7.5
Old Sep 4, 2006 | 11:18 PM
v6 5 speed s-10's came with the 8.5
i know that for a fact, samdogmx on here swapped his posi from his s-10 to his fullsize
and i could have sworn f-bodys came with 8.5's also, i could be wrong here though
Old Sep 5, 2006 | 07:38 AM
quicksilverado's Avatar
F-bodies have 7.5 inch rears.
Old Sep 5, 2006 | 07:50 PM
COLDZ71's Avatar
So what your saying is that I can pull a carrier out of a Camaro and put it in my truck???????? I am pretty sure the 1 inch difference in carrier size would make a it a little bit tricky bolting them up. I am just wondering if car and truck 8.5 inch 30 spline carriers are the same.
Old Sep 5, 2006 | 09:18 PM
no you can not interchange the 7.5 and 8.5
but if you had an 8.5 from an s-10 and an 8.5 from your truck they would swap
i dunno what comes in f bodys specifically, if they are 8.5's and 30 spline i'd assume they would work
but quicksilverado says they are 7.5's
