Caltracs and still have axle hop...
Old Dec 6, 2011 | 05:45 PM
08k1500_3's Avatar
Default Caltracs and still have axle hop...
So I installed my Caltracs this weekend and have them set at 1/4 turn prelode and still have bad axle when it was wet this morning I had my damn axle still!!!
I am going to try another 1/4 turn tomorrow and see what happens...
What are you guys running for preload on your DD trucks with Caltracs?
Thanks, Matt
Old Dec 6, 2011 | 07:32 PM
LS1TRUCKGUY's Avatar
I don't run any preload on the street. I tighten them until it makes contact with the leaf spring and thats it. I get no wheel hop like this. I will get a little tire chatter sometimes as the tires fight for traction, but no wheel hop. Did you use the aluminum bushings in the leaf spring eyelets?
Old Dec 7, 2011 | 01:27 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Are your shocks worn out? Could you give us more info on your suspension setup? Are you still rocking the Gov-Bomb?
I have mine set to 1/4 turn after touching when the canopy is off, and a little tighter when it's on.
Old Dec 7, 2011 | 05:34 AM
08k1500_3's Avatar
Rear suspension is stock with the overloads taken out.
Yes I used the Aluminum bushings
Never had a G80. I run a Powertrax quikloc
Old Dec 7, 2011 | 07:20 AM
tarinitup's Avatar
9 Second Truck Club
How's your pinion angle?
Old Dec 8, 2011 | 12:01 AM
I had to add a 4 degree wedge with my setup to get the pinion angle right. You'll need to get a gauge on your setup.
You never said anything about your shocks....
Old Dec 8, 2011 | 07:12 PM
08k1500_3's Avatar
Shocks are 4 months old ranchos.
I am going to put a pinion gauge on it this weekend and see where we go from there
Alco
Jul 20, 2016 04:53 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
twake_410
Sep 25, 2015 10:09 PM
pewter00
Sep 13, 2015 11:14 AM
