Caltracs or Drag slicks? (4wd)
Old Dec 22, 2006 | 09:48 AM
Wilde Racing's Avatar
How do I change this text
Default Caltracs or Drag slicks? (4wd)
O.K I've been planing on buying some drag tires for quite some time. But I have had a few problems finding 30" tall drag tires. I did find M and H 30x14x16lt tires but I think they might be a bit big for the front of the truck. Then my uncle asked "why not caltracs?". I said "I don't know"... lol
So what does everyone think? 4wd with caltracs and stock tires or M and H drags. I know the drags will mostlikely hook better, but I just need a bit more traction. My best 60' is 1.67 and that is at about 6 psi at launch. I can hit 8-10 psi if the ride wasent so rough......
Thought?
I might just ****-can the hole idea, be WAY nice to my wife for a month and pray Parish8 don't sell his tires by then....
Old Dec 22, 2006 | 10:46 AM
TURBO8's Avatar
I say caltracs. I think it will smooth it out alot. In turn you will be able to launch harder. Those tires are really wide for the front. they may slow you down on the top end.
Old Dec 22, 2006 | 11:38 AM
Dock Rocker's Avatar
Do both. put some slicks on the back (you may have to go with 29 in) with the caltracs and put some good sticky street tires on the front. With the weight transfer the back is going to do most of the work anyway.
Old Dec 22, 2006 | 11:54 AM
I'm tring to do this VERY cheap, so both isn't going to happen unless I can find everything cheap of course. Why 29" tall tires, Dock Rocker? what is wrong with the Mand H's?
Old Dec 22, 2006 | 12:34 PM
Last Call's Avatar
TOTM: January 2007
I say Caltracs. Not even sure if slicks will fix the wheel hop you have going on in the rear.
Old Dec 22, 2006 | 12:37 PM
2004SSS's Avatar
well im guessing your trying to stay out of 4 th gear by getting the taller tire? i think i calculated it ot be like 125 or so crossing the traps in 3rd at like 6100 rpms, if do the 28.8 tall tires will work, imo i would get slicks you could get some good 60 ft's with them . i know im awd but i pulled a 1.60 60 ft with them last time out.
Old Dec 22, 2006 | 12:50 PM
vanillagorilla's Avatar
I would be worried about having full on tall slicks on the front tires, in case you have to steer and correct. I think they could roll and fold which would cause you to lose control. I would do drag radials on the front due to their more rigid construction, but not slicks.
Old Dec 22, 2006 | 12:52 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Just run skinny tires of the same diameter up front, slicks or DR's in the rear, 4Hi launch and go!!
Old Dec 22, 2006 | 01:00 PM
jgun's Avatar
Question
where can someone get a set of caltracs. Can you run caltracs with shackels and hangers on a truck????????
Old Dec 22, 2006 | 01:15 PM
I think this is my cheapest bet.... I would like the looks of drag radials on both end though
vanillagorilla, no one makes 30" dot radials. I'd have to go to 28" and that puts me over my personal rpm limit.
