caltrac dimensions for flip kit
Old May 8, 2010 | 12:29 PM
LS1TRUCKGUY's Avatar
Default caltrac dimensions for flip kit
i need to know the distance from the plate that bolts to the bottom of the leaf spring to the center of the hole where the heim joint bolts through. thanks in advance
Old May 8, 2010 | 08:52 PM
anyone?
Old May 9, 2010 | 02:40 AM
Daryn's Avatar
Formerly darynC-10/23/10
just wing it
Old May 9, 2010 | 07:57 AM
blown02408's Avatar
02 w/ lowest mileage 2800
33 1/2" center mounting hole to center of lower mounting hole, 30" bar length without heim joints. Center of spring eye to center of lower mounting hole 4 1/4". Hope this helps.
Old May 9, 2010 | 08:51 AM
thank you sir i have a set of caltracs for a non-flip kit truck, so im modifying my plates for the flip kit version. thanks a ton
Old May 9, 2010 | 09:26 AM
TXsilverado's Avatar
theres no difference in the bar between the flip and non flip. just weld the tabs to the center of the plate and go with it.
Old May 9, 2010 | 10:27 AM
bluecajun5.3's Avatar
11 Second Truck Club
yes there are. the flip kit bars are a little longer.
Old May 9, 2010 | 11:45 AM
hell, my non flipkit bars are almost too long lol. when i did my flip i just called calvert and got a new plate to bolt to.
Old May 9, 2010 | 01:40 PM
that's weird. i will try to get the measurements. it wasn't much, maybe 1/2".
Old May 9, 2010 | 01:58 PM
007gmc's Avatar
When i did my flip kit I just made new brackets and welded them to the bottom plates that came with the flip kit. I made the bolt center 3-1/2" under the leaf. Works great
