caltrac dimensions for flip kit
Old May 9, 2010 | 05:36 PM
LS1TRUCKGUY's Avatar
I figured it would be longer to clear the leaf spring on the flip kit version... the plates from calvert racing are $60 so I am just gonna weld some tabs to my flip kit
Old May 9, 2010 | 05:41 PM
Originally Posted by 007gmc
When i did my flip kit I just made new brackets and welded them to the bottom plates that came with the flip kit. I made the bolt center 3-1/2" under the leaf. Works great
Do you have the overload leafs, or no?
Old May 9, 2010 | 06:13 PM
blown02408's Avatar
02 w/ lowest mileage 2800
I removed my overloads because the bars were hitting them, i think it also helped the caltracs function better since they work off of spring wrap.
Old May 9, 2010 | 09:18 PM
TXsilverado's Avatar
since you are going from scratch...to find the right spot to punch the hole in your new perch:
put an angle finder on the bar and move it around to find the right spot to drill the hole for the heim joint to bolt into. from the playing ive done, the cal-tracs work best when the bar is sitting as parallel to the ground as possible. mine sit at a perfect 0* on a level ground. here lately with the new tires and figuring out the preload and shock settings i am dead hooking 1.67 60' times. not even a squeak. if i unload the traction bars it goes from 1.67 to about 1.75 to 1.80
Old May 9, 2010 | 11:37 PM
007gmc's Avatar
Yes, and I'll never put them back in my truck. I still cary a 400 lb. four wheeler in the bed just fine with out them.
Mine are level after making my new brackets for my flip, they work better than the original ones before it was flipped.
Here is a pic of the brackets I made and welded to my flip kit
Old May 10, 2010 | 05:16 AM
blown02408's Avatar
how much preload are you running?
Old May 10, 2010 | 08:03 AM
ok sweet. this helps a TON. anything i can do to get my 60' down will be a blessing. thanks guys
Old May 10, 2010 | 08:58 AM
my truck seems to like alot of preload. probably because i took out the overload spring. ecsb might have somehting to do with it too?
here is how i set things. with the truck on a level ground and at your race weight i set the bars to where the bolts just barely touch the top of the spring pack (do this on both sides) this is important because after adjusting one side, it will change the other side.
on the passenger side i give give it 3/4 turn preload. then i go to the driver side and give it 1/2 preload. rancho 9000x shocks set to the 7 setting. i put a jack under the frame of the truck to give me a the room to adjust the bar without using a wrench.
i know calvert says to only give it 1/4 on each side, but that didnt work for me at all. in the end i think you just have to play with your setup. everythign will act different. im pretty sure flaco told me he just gives it a 1/4 turn on the little sister and everyone knows how good it hooks. he might try the method that works on my truck and blow his tires off.
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Nov 5, 2015 06:49 AM
YenkoST
Aug 28, 2015 01:42 PM
323steel36
Aug 25, 2015 05:11 PM
121
Jul 16, 2015 12:18 AM
