Calling all suspension gurus.
Old 08-05-2009, 09:00 AM
RED04REGENCYRST's Avatar
Default Calling all suspension gurus.
im thinking bout changing around the front suspension on the rst, my question is.... would i get a better combination of handling/ride comfort if i went with a set of aftermarket lowered control arms and stock springs or with stock springs and a dropped spindles?
the truck currently has ground force drop springs and stock control arms and spindles. im lookin for the same ride height just trying to get away from that damn stiff *** front springs. the truck is sitting on the bump stops when its parked in the driveway so it rough sometimes out on the road. i was thinking by going back to the stock spring the suspension might have alittle more travel and therefore give me a smoother ride on those bumpy streets. please correct me if im wrong.
Old 08-05-2009, 12:27 PM
Tootall's Avatar
put the stock front springs back in, and get some drop spindles . . . how much of a drop are you doing ?
Old 08-05-2009, 12:36 PM
LowSilver's Avatar
I went with the DJM 4/6 drop, which is a stock spring, combined with a new lower control arm. I am very pleased with how it rides. It is soft, yet you can still throw the truck into a corner with good control.
its like 1.5" - 2" drop right now. so thats kinda where i wanna stay.
Old 08-05-2009, 12:42 PM
LowSilver's Avatar
Yeah, if it is only 2" I would do a spindle. It is probably the cheapest.
Old 08-06-2009, 06:30 AM
whats your guys opinion on the best product to go with for a drop spindle?
Old 08-06-2009, 09:36 AM
LowSilver's Avatar
I have a set of belltech's in my Sonoma and also had a set in an S-10. I was quite happy with them. That is the only experience I have had with spindles
Old 08-06-2009, 05:50 PM
1quickRST's Avatar
Being an RST owner, I am all too familar with our suspensions. First off, I would just cut some of the bump stop away. I did this on my truck and it rides WAY better, then if you are still running the Nitro drop shocks the truck came with, pull them out and burn them. Then go buy some stock KYB's and put those in and your truck will ride SO much better! Promise! as for the back end, cut some of the bumpstop off of there too and see how much that helps as well.... Oh and I am not just saying this, everything I just told you to do I did to my truck, so I know it will make a difference....hope this helps!
Old 08-08-2009, 04:36 AM
12 Second Club
AdioSS's Avatar
+1!
The biggest thing to look at when you want a smoother ride are the shocks, tires/wheels, and is the suspension binding up or hitting anything anywhere (bumpstops in this case.)
Try doing what he said with the bumpstops first since it is basically free. Then, if you haven't already, change the shocks.
thompson
12-27-2017 06:48 AM
gmcyukon
10-05-2015 06:20 AM
KINGCYCLES
10-02-2015 10:21 AM
Cammed4ever
09-30-2015 03:38 PM
Rockrz
09-29-2015 09:07 AM
Quick Reply: Calling all suspension gurus.
