burnout
Old Feb 4, 2009 | 08:18 PM
oldred95's Avatar
Originally Posted by 95 bright teal
With your cam you should still have plenty of low end grunt, and the stall/gears should make it easy for you.
Do you still have your stock rims/tires you could put on. you weigh more, and have heavier wheels which doesnt help with burnouts
Wheels don't make that much of a difference, not when you've got 4.10s and a 3.06:1 first gear ratio.
FWIW my 95 blows both tires off with ease just from a standing throttle stab, no brake or anything and thats through a 4L80E, the stock 1400 rpm stalling diesel converter, 3.73s and 32 x 11.50s, and it was dipping as low as 10.5:1 in PE at that. I'd say the guy has got something wrong somewhere.
Old Feb 4, 2009 | 09:32 PM
way2much_01's Avatar
the converter is stalled at 2600... even with the stock tires I can't do it... theres gotta be something in the tune that will fix it...
Old Feb 4, 2009 | 09:42 PM
outlawz2004's Avatar
It should be blowing the tires off the thing. How hard are you holding the brake. I would be thankful it hooks.
Old Feb 4, 2009 | 09:47 PM
KevinF56's Avatar
you sure that traction control is turned off?
Old Feb 4, 2009 | 09:48 PM
I gotta put my foot in the brakes other wise it'll just go
Old Feb 4, 2009 | 09:52 PM
oldred95's Avatar
Either the torque management didn't get turned off, you've got a lean condition, a rich condition, or just a pathetic spark advance table. Even with torque management it still ought to be able to at least get a little wheel spin going with that many mods and the gearing.
Old Feb 4, 2009 | 10:00 PM
454navyss's Avatar
you might just be pressing the brake too hard. in my truck if i push the brake too hard it doesnt want to spin until i ease off the brake a little.
and 20s make a HUGE difference over stock wheels. with my 20s it will spin a little if i punch it from a stop but with my 16s i can smoke the tires from 30 mph
Old Feb 4, 2009 | 10:15 PM
OldRed, why dont you say what you said on the other site about this thread?Here I will post it for you:
Maybe maybe not. Those guys seem to be insulted by lowend torque and I think its funny. I have zero issues what so ever making a 4L80E with the diesel converter that stalls at a whopping 1400 rpms with 3.73s and 32 11.50s burn both tires. Torque vs no torque. I just think its funny.
http://www.fullsizechevy.com/forums/...ough-time.html
Old Feb 4, 2009 | 10:33 PM
oldred95's Avatar
Ok. Either way he's clearly got a torque problem. Whether the engine can't physically make the power or its a tuning issue isn't known but either way it takes torque and a lot of it down low to make a 5500 pound land yacht move.
How does it run other wise? Is the engine in good mechanical condition? Whats it do is you give it a little hit of nitrous? Surely that would get things spinning.
Old Feb 4, 2009 | 10:38 PM
LA CHARANGA's Avatar
throw some water on dem bishes
