burnout
Old Feb 6, 2009 | 09:44 AM
  #31
nonnieselman's Avatar
Originally Posted by silver-mod-o
Consider it a blessing
I agree!!
Some people wanna hook, others wanna spin..
Brake Torque Management???
Old Feb 6, 2009 | 11:38 AM
  #32
way2much_01's Avatar
It's 2wd by the way
Old Feb 6, 2009 | 04:35 PM
  #33
1quickRST's Avatar
I might have missed it, but are you trying to spin the tires during a break stand or from a stand still at a street light. Those avalanche's are heavy but it should be able to at least spin the tires from a stand still. Where are you located in Cali? I have a shop here in the bay area that might be able to help....
Old Feb 8, 2009 | 01:13 AM
  #34
Fast355's Avatar
Its a TORQUE problem, considering I can get a nice squak EASILY by brake stalling to 1,000 rpm and stabbing the gas. This is in a fullsize conversion van with P295/50/R17s, 3.08 gears, and a true-trac. As it was said earlier, it takes TORQUE to move a land yacht the way you are wanting and the newer engines come up a little shy. With 3.73s and a 2,600 rpm stall or so, it would be much easier for me to light them up.
http://s243.photobucket.com/albums/f...=101_1468.flv]
This is what happens when I power brake it a little.
Old Feb 8, 2009 | 09:51 AM
  #35
outlawz2004's Avatar
[QUOTE=Fast355;4122856]Its a TORQUE problem, considering I can get a nice squak EASILY by brake stalling to 1,000 rpm and stabbing the gas. This is in a fullsize conversion van with P295/50/R17s, 3.08 gears, and a true-trac. As it was said earlier, it takes TORQUE to move a land yacht the way you are wanting and the newer engines come up a little shy. With 3.73s and a 2,600 rpm stall or so, it would be much easier for me to light them up.
Oh take that "new engines have no torque" bullshit back to fullsize chevy.
Old Feb 8, 2009 | 09:55 AM
  #36
Fast355's Avatar
I don't need to take something back to FSC when its the truth. There is a reason getting good performance out of the LSx requires a higher stall converter. The head ports, intake manifold, and camshafts push the peak torque RPM way higher than an old school small block. While this is not necessarily a bad thing, its a detail. His cammed 5.3 is not generating enough torque at the 2,600 rpm stall speed of his converter to burn the tires or else he would be burning up the road. I'll say it again even, I had NO difficulty getting my 305 to put out enough torque to burn 29" tall 295mm wide tires with alot more weight over them than an Avalanche, with 3.08 gears and a 1,600 rpm converter.
Before you start bashing, I know exactly how to make the LSx perform and perform well, so get that out of your mind. I also have a 2006 Dodge Ram 1500 Quad Cab with a SOHC 4.7 and its even worse. The torque curve is all in the mid-upper rpm band on that truck with very little under 2,500 rpm. The 3.7 Jeep Liberty converter thats in it now stalls around 3,200 rpm behind the 4.7.
http://s243.photobucket.com/albums/f...t=63b23fd6.flv
Old Feb 8, 2009 | 10:08 AM
  #37
Even this thing can do a burnout, it shows nothing on how much power the thing has.
http://www.youtube.com/watch?v=bDMX3mpe9Go
Old Feb 8, 2009 | 10:36 AM
  #38
Mark Johnson's Avatar
Sounds like there's some flex happening somewhere; some axle wrap what have you. Cal tracs may be the solution....................
Old Feb 8, 2009 | 10:37 AM
  #39
budhayes3's Avatar
PT's Slowest Truck
I don't think that burnouts mean a whole lot...I used to be able to smoke my 33's with bolt ons and the stock tune, running 16.5 1/4's...with a 2.6 60' time.
Old Feb 8, 2009 | 11:10 AM
  #40
006rcsb's Avatar
lol yeah too much axle wrap put caltracs on it.........oh wait its a trailing arm and coil spring suspension
