View Poll Results: Are you interested in a group buy of a metal fab'd clutch pedal bracket solution?
Yes - roughly $250-$300 is fine
86.67%
Yes - but I need a less expensive price tag
13.33%
No - I have a better idea (describe below)
0%
Voters: 15. You may not vote on this poll
Broken clutch pedal brackets - gauging interest in metal fab'd bracket solution
Old Jan 28, 2018 | 09:35 AM
  #81
262_NBS's Avatar
On the A4 to M6 swap thread, vanilagorilla fabbed a small tab with two threaded holes that the auto trucks lack. First post..a few pictures down will explain it.
https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/official-a4-m6-t-56-thread-381877
Old Jan 28, 2018 | 12:33 PM
  #82
drowssap's Avatar
Registered User
I wonder if he had that problem because his truck was a 2000 or if everyone here that has done the swap just simply went through the firewall
  #83
Atomic's Avatar
I have a gauge for that
Where does that little tab sit? I can certainly make a piece but need some measurements or that piece to copy. What do the factory trucks have there?
Old Jan 28, 2018 | 12:48 PM
  #84
drowssap's Avatar
Registered User
I will definitely be waiting for that! Has anyone figured out if the clutch needs to be shimmed or did an adjustable slave rod fix the low pedal grab issue?
Old Jan 28, 2018 | 12:51 PM
  #85
262_NBS's Avatar
The tab sits inside the stamped rectangular box to the right of the slave hole in the firewall in picture #1 ... the two firewall bolts thread into it.
AFAIK GM does not sell that piece anymore.
Old Jan 28, 2018 | 02:52 PM
  #86
2002_Z28_Six_Speed's Avatar
That fabbed mounting location bracket would have been nice to have. I pulled the entire brake booster reinforcement bracket and welded two nuts to the back.
I am working on looking into the low pedal issue. I checked into shimming but only after i had already installed the tranny and realised there might be an issue. it doesn't look like a shim should be needed but I didnt go through the steps of measuring as i was not aware of the correct steps and didnt' think it would be needed on a factory set up. If you search for the tick performance SC shims it tells you how to determine if a shim is needed. If someone would volunteer that would be awesome but I dont feel like pulling a 200 lb tranny for fun. Tick said the shims were compatible IF needed btw.
GM does still sell a MC with a longer pushrod. I plan on installing this to test it at the same time as I install the atomic bracket. I got the part in the mail a couple of days ago. GM 24242325 The only thing that is different is the pushrod so it might be worth it to just mod an existing rod instead of buying new set up.
SilveradoSierra.com ? 2006 sierra clutch problem : Transmission/Drivetrain
#PIP3864F: Low Clutch Pedal And Possibly Hard to Shift - keywords gear grind - (Mar 23, 2007)
Subject: Low Clutch Pedal and Possibly Hard to Shift
Models: 2006-2007 Chevrolet Silverado
2006-2007 GMC Sierra
Equipped With a MG5 5-speed Manual Transmission and 4.3L LU3 or 4.8L LR4 Engine
This PI is being superseded top update Recommendations/Instructions. Please discard PIP3864E
The following diagnosis might be helpful if the vehicle exhibits the sympton(s) described in this PI.
Condition/Concern: Clutch will not release until almost to the floor, vehicles will have been built in Silao Mexico.
Recommendation/Instructions: Replace the clutch master cylinder assembly with a new MC part number 24242325. This MC will be equipped with a longer push rod.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Anyways sorry to go off topic.
Old Jan 28, 2018 | 04:19 PM
  #87
Atomic's Avatar
If it helps, I can make the snout of the bracket that controls rod length as short or long as I need to. I tried to match the factory distance as it is.
Old Jan 28, 2018 | 08:32 PM
  #88
262_NBS's Avatar
Autozone and Advance/Carquest both sell a replacement metal master and pushrod
Old Jan 29, 2018 | 07:38 AM
  #89
You got part numbers on those?
Old Jan 29, 2018 | 09:23 AM
  #90
262_NBS's Avatar
Search either website 13493
