Broke rear end today. Need advice quick
Old Nov 25, 2006 | 09:56 PM
tarinitup's Avatar
9 Second Truck Club
Default Broke rear end today. Need advice quick
I finished my burnout and broke the rear on the launch. Rpms went to 6000 and speedo hit 100mph but truck didn't move. Track guy said it probably only broke the spider gears or yoke ( i dont know about rear ends) since it didn't move. Will the stock g-80 survive something like this or should I just order an eaton lsd? What does it normally run and where is the best place to buy? Thanks
Old Nov 25, 2006 | 10:00 PM
tarinitup's Avatar
9 Second Truck Club
what do I need to buy so that this won't happen again?
Old Nov 25, 2006 | 10:02 PM
quicksilverado's Avatar
Eaton posi will take care of the problem.
Old Nov 25, 2006 | 10:17 PM
Derek @ EDO's Avatar
FormerVendor
eaton or tru trac they dont call them G-80's for nuthin
G- stands for Grenade.
Old Nov 25, 2006 | 10:56 PM
KySilverado's Avatar
Cheapest I've seen them is on E-bay. $349-379 + about 25 shipping.
Old Nov 26, 2006 | 01:23 AM
James B.'s Avatar
I hate to say this, but you need to start setting aside as much money as you can. Sometimes when these things pop it locks up the ring gear and breaks the sprag in the trans. If that happened you won't have any first or second in Drive or 3, but it will give you a very weak first in manual first and the same for second. It's enough to move the truck but there's no torque handling because the overrun clutches do all the work with no sprag.
Old Nov 26, 2006 | 08:56 AM
tarinitup's Avatar
9 Second Truck Club
James B, what you described seems painfull and expensive so I really hope that's not the case.
Old Nov 26, 2006 | 09:36 AM
tarinitup's Avatar
9 Second Truck Club
Default Will one of these work? Which is better?
http://cgi.ebay.com/ebaymotors/Aubur...55149860QQrdZ1
http://cgi.ebay.com/ebaymotors/GM-CH...spagenameZWDVW
Old Nov 26, 2006 | 10:51 AM
Coban's Avatar
Auburn is no good.
Choose the Eaton over it for sure.
Might also want to look at the true track.
Old Nov 26, 2006 | 12:31 PM
Ruffrider5.3's Avatar
That happen to me in my Z28 one time and is was not the rear end but the tranny clutches slippin. Can you roll the truck at all? Maybe it be the tranny.
