Break Pad Life?
Old Feb 5, 2005 | 07:47 PM
GoldenVelvet's Avatar
Default Break Pad Life?
Like the title says; What is the normal break pad life expectancy? I remember this being discussed previously but I couldn't find anything with the search button. ("We have a search button!?")
Old Feb 5, 2005 | 08:04 PM
chris99gmc's Avatar
it all depends on how you drive the truck. Wheel and tire combos are also a factor. BUt i would say anywhere from 20-60k on a daily driven normal car.
Old Feb 5, 2005 | 09:23 PM
I'm at 65k and haven't touched em
Old Feb 5, 2005 | 09:25 PM
SnakeOiler's Avatar
Same with me. 62K, not touched. Mostly highway miles, though, in a Nothern Virginia commute.
Old Feb 5, 2005 | 09:29 PM
desTRUCKtive's Avatar
I am almost at 70 and they still look fine. But my brake light went on, so I am wondering if that has anything to do with that. The pads on these things are the best I remember right before they came out with the these trucks, they said that the life expectancy on the pads was going to be three times as much as the 98 and lower silverado's
Old Feb 5, 2005 | 10:09 PM
KeukaZ71's Avatar
i've heard of some guys on here that were getting 150k on the same pads and rotors
Old Feb 5, 2005 | 11:24 PM
mjgjr72's Avatar
2000 silver ecsb w/35 tires 50k and haven't done fronts, 40k did rears because sliders wear sticking and wore out inside pads on rear
Old Feb 5, 2005 | 11:26 PM
goshawk23's Avatar
Truck addict
i put about 105K on my rear pads and i am still on my stock front pads at 113K. my truck is an 01. so they have lasted quite a while. i have my pads in the garage waiting for the front to start to fade and squeel but so far they are holding up. i tow some heavy stuff from time to time and they still stop like always.
Old Feb 6, 2005 | 02:38 PM
Is this kind of common for these trucks the rear pads going first than the front ones. That is weird becuase the rear pads should be lasting longer than the front ones.
I also heard that the emergency brake needs to be adjusted every now and then on these, if not it can cause premature wear on the pads and ruin the rotors, is this true.
Old Feb 6, 2005 | 02:49 PM
KeukaZ71's Avatar
ya you would think the rears should last longer. i guess it is because they get alot of debris caught in there.
my e-brake sucked. i ripped it out when i replaced the rear rotors
