Brand New 4l60 and ABS problems???
Hey guys first off let me say long time reader first time writer on here. I just installed a brand new 4l60 in my DD truck took old one out put new one in no problems but now my abs kicks in at low speeds like stopping at a stop sign or something then every now and again the "service brake system" comes up. Is there a sensor or something I can check to get this to stop? Is this common? Otherwise everything is great on it the new tranny has 350 miles on it and this only problem I have had any suggestions would be great. Thanks in advance
Goose I posted on your other thread on tech. With you having issues with the vss I can see where this might be a problem. Make sure you connections at the transfer case is solid. Pins and wiring would be what you need to look at. If all this is fine and the problem still exists then try swapping in another sensor. Vince
hey just wanted given a long over due update that the VSS wasn't screwed in right but everything is ok as of now been running real good..i appreciate the help you guys gave me..saved a lot of time
Ken in AZ
Sep 17, 2015 07:08 AM
Fast86z
Aug 23, 2015 12:35 AM
97aztecgt
Aug 13, 2015 02:11 PM
