Braking causes vibration
Old Nov 28, 2010 | 09:36 PM
BigE's Avatar
Default Braking causes vibration
I bought a 2005 CC Z71 that came complete with a brake-induced vibration or shimmy. The truck just rolled 50k miles yesterday. When driving at a moderate to high speed and applying the brakes, I get a vibration. It felt just like warped rotors. I pulled the wheels yesterday and put a dial indicator on both rotors. They're not warped. With the front brakes seemingly being okay, I started poking around the front suspension and steering. I found some play but I'm hesitant to say it's the source of my problem. With the front wheels off the ground, I put one hand around the pitman arm at the steering box and with the other hand, moved the tires left and right. I could feel a small pop or clunk at the steering box/pitman arm when changing directions. It could be the pitman arm, but it almost feels like the slack is in the box. Either way, the truck is stock with only 50k miles on it. I'm having a hard time understanding the premature wear. Anyone else have a similar problem? What was the solution?
Old Nov 28, 2010 | 09:46 PM
MikeGyver's Avatar
Check your rear brakes. I swore it was my fronts, but when I found the condition of the rears and had them turned, the problem went away for awhile. It came back because the rears were junk.
Old Nov 28, 2010 | 10:00 PM
Atomic's Avatar
I have a gauge for that
Did you put the lug nuts on the rotors to hold them flat against the hub when you checked the runout?
Old Nov 28, 2010 | 10:16 PM
Mangled03gmc's Avatar
Baltimore Whore
Rear brakes have been a problem from what I understand( discs) As for the pop your feeling mine does it also, but just in the left front wheel, doesn't affect my drive at all, not a vibration untill the brakes are heated, then I get a shimmy also.. I know my discs in the rear are messed up, can feel it really bad when slowing down after blasting down the 1/4 and getting on the brakes.. I say check the rears if you have discs
Old Nov 29, 2010 | 01:32 AM
BigE's Avatar
I did not put a lug nut on the rotor but it had a Torx screw holding it on. I tugged on it and it did not budge.
I'll check out the rears just to be sure. My rear brakes are drums, though.
Old Nov 29, 2010 | 06:50 PM
KleenHall's Avatar
brake shake in the wheel is the front and in the pedal is the rear
disc or drum
Old Nov 29, 2010 | 08:43 PM
andrew383's Avatar
traveling mod
Id say turn the rotors...
Old Nov 29, 2010 | 09:01 PM
MikeGyver's Avatar
disc or drum
My bad rears made the steering wheel wiggle.
Old Nov 29, 2010 | 10:28 PM
matt29201's Avatar
05 should have rear drums. if the runout on the front rotors is within specs or less than .003 runout i would have the rear drums turned.
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
Noah Burns
Sep 13, 2015 09:28 AM
Alco
Sep 4, 2015 04:08 PM
